How do you remove the mechanical fan?
eyehatetofu
Buckeye, AZ
OK so I'm replacing my radiator and water pump. Everything is going smooth until I get to the mechanical fan. Can't for the life of me get this thing off. I have been at it for the past two hours and have decided to give it up and see if anyone has any backyard hillbilly way to get this off.
First I tried hitting the wrench with a hammer. That didn't work so then I removed the serpentine belt and tried a strap wrench to hold the pulley and broke the strap. Tried to use my belt (that holds up my pants) and broke my belt. Tried to stuff a couple bolts through the holes in the pulley and bent the bolts. This fawker ain't coming off. Anyone know how the hell to get this off with out specialized tools?
I have searched and unless the answer is buried in some obscure thread the only answer I saw was TJKJ's air hammer and special wrench.
Get the proper sized wrench for the nut, then put a bolt through one of the holes in the water pump long enough so that it'll catch on a fin to stop it from spinning.
Edit: You already tried the water pump thing?
eyehatetofu
Buckeye, AZ
I have the proper sized wrench and tried this. I gouged the shit out of the water pump and bent the bolts. No bueno. :(
What is the water pump thing?
tombo_ontario
Windsor, Ontario
I was able to break mine free using a big a** wrench and a BFH. Gave it a few HARD whacks with the belt still on and somewhat holding the pulley with my hands and it broke free. Maybe I just got off easy...
The bolt through the hole thing, sounds like you tried it. Maybe use stronger bolts?
M38 Bob
Arkansas
Broke strap wrench. Broke belt. Bet my ass against 9 green walnuts you won't break one of these! The Original
Takes a bit of common sense when clamping it around the pulley to not damage it, and they ain't cheap. But once you buy one of these you'll find it the handiest thing since mammary glands on wimmin!
eyehatetofu
Buckeye, AZ
I use a large pipe wrench and a universal fan clutch holder from napa. NAPA AUTO PARTS | PART DETAILS
Just went to Napa a bit ago and bought this. And... Broke it. It had two nubs on the end so I put those in the pulley holes and broke one of the nubs off. Then used it to clamp the backside of the pulley with the other hook end in the pulley hole and it twisted and bent to shit.
Gonna go and drink beer and worry about this tomorrow. :thumbsdown:
The first time I took mine off was very tough. I did have a very sturdy clutch fan wrench to fit it (36mm IIRC) and a generic pulley holder that is also very sturdy. I wedged the pulley holder and hit the wrench sharply with a metal hammer. Try spraying some penetrating stuff in there and let it soak.
Just wondering, You are going CCW right? I think when I first tried mine I saw some conflicting thread directions on the world wide internet web.
If you ever do get it off use some antiseize when you put it back together. I'm thinking of getting the set that TJKJ mentioned.
CzarKJ
Townsend, MA
Well ****. That's really on there....
^^That^^
When standing in front of the Jeep you should be turning your wrench to the LEFT (Counter Clock Wise) to remove it. I agree with Itd02 - many conflicting reports on the direction the engine spins the fan to tighten it which confuses people trying to remove it. Basically, it's like any other standard bolt - righty/tighty, lefty/loosey. (I hate that phrase, by the way :emotions34: )
eyehatetofu
Buckeye, AZ
^^That^^
Yup. Lefty loosely. I searched and checked to make sure I was doing it right.
Leeann
Maryland
Got an air hammer/air chisel? Generally, a couple hits with that and they're loose.
(I hate autocorrect...)
M38 Bob
Arkansas
If I'm the least bit unsure of direction I take a look at the replacement.
Sent from my iPad using Tapatalk
turblediesel
memberable
Alaska
A CRD thread somewhere showed someone using a palm nailer for impact on the wrench. Took 4 hands to keep pins engaged and about 5 solid hits with a small sledgehammer to get mine loose.
One of the tiny butane torches might help.
M38 Bob
Arkansas
Heat will be ok IF you plan to replace the thermo clutch as well.
eyehatetofu
Buckeye, AZ
Success!!! I work 12 hour days so the Jeep was on hold til my work week was over. I have been soaking the nut in PB Blaster every night after work. Finally had time this morning to work on my pile and boom got the nut off. I ended up putting the belt back on and all it took was a little tap on the wrench from a hammer.
Now I got to stop patting myself on the back and finish the job. :D
eyehatetofu
Buckeye, AZ
So pb blaster was the savior. who would have thought.
Right? :D
I haven't had to many issues with stuck bolts / nuts / fasteners, and being in AZ rust isn't really an issue. Now I know to hit a nut / bolt with PB Blaster before I go breaking tools and shit. Live and learn. :happy175:
