Luke
Interloper
I would like to have a short recording follow up my horn blast.
HOOOOOOOOOOOONK - You ******
HOOOOOOOOOOOONK - What the hell.
HOOOOOOOOOOOONK - Speed up or move aside a-hole.
Yesterday we are stuck at the intersection with a car trying to park, about 4 cars up. The A-Hole behind me honked, and honked and honked. So I pulled slightly to the right to make sure he can see me, and rolled down my windows stuck my head out and said "where the hell are you gonna go? Huh?".. So another cool upgrade would actually be a loud horn in the back, facing rear!. Honked me? HONK YOU!![]()
I installed a grover dual tone in mine. way louder than stock and will scare the hell out of anyone. i got it off a dumptruck in a junk yard for 15 dollars. after air compressor, air tank, hoses, mounting metals, 85/105 air switch, solenoid, wiring, relays and fuses, i probably spent around $400. a decent air compressor is what costs you (assuming you install it yourself) i did it the first time using cheap stuff and it lasted for a week, pep boys air compressors suck, i went through 2 before buying a good one (which has lasted over 2 years so far) the horn and compressor are mounted where the factory airbox was. the 2 gallon air tank is on the pass. side behind the radiator. i have it wired wired through the fuse panel to the radio fuse so that i can use the key to controll it (love the loud chirp get now when i lock the jeep) also keeps the compressor from running when you forget to hit the kill switch after leaving your kj (always install a kill switch anyway) Needless to say neighbors arent happy when some kid sets the alarm off. have pics if interested.
hmm my pics are missing ill take some more later.
here are some pics of the first setup. you can see the cheaps parts i used and the ugly red everywhere. the current set up is way better. im almost too embarrased to show these.
here are some pics of the first setup. you can see the cheaps parts i used and the ugly red everywhere. the current set up is way better. im almost too embarrased to show these."
Sweet! Got a vid of it in action?
