What year KJ??? do you have?
2007 KJ ok well..
There should be a puddle light wire taped on the steering column left side, by black tape with a small little connector on it. Remove kick panel just below steering column to find it and look up with a bunch of other wires.
You can tie a few LED lights into that no problem. Just disconnect the battery as there is some residual power in wire.
One Dealer light bulb for puddle light was 8 watts. One group of 3 LED is about .75 of a watt.
Here you can see I used an amber 3 led on each side from bluewater...(dont see the 3 led listed now)
http://www.bluewaterled.com/catalogdetails.php?id=26
37836[/ATTACH]"]
