Help me find the hissing noise
Vtolds
Stowe, VT
I replaced my exhaust yesterday because the stock one had a whole in the muffler. Before I had a noticeable hissing noise that I figured was the hole in the muffler. After replacing the muffler and determining I have no leaks the hissing sound is still present.
http://s2.photobucket.com/albums/y2/Vtolds/?action=view&current=JeepExhaust.mp4
What could it be? The sound does disappear when I hit the gas, I am thinking it could be something fuel pump related but I dont have the skill to determine that for sure.
mag03kj
LOST
K
I had the same sound. I had 2 diff. places it was doing it tho!
1) It was on the driver side on the firewall. Hose was cracked!
2) It was a fuel line under the drive door! Hose was cracked!
Replaced both and the noise stopped!
ptsb5a
Northern Alberta, Canada
K
Fuel lines don't hiss dude, they piss fuel out everywhere. Sure it was a fuel line and not a vapour recovery something or other?
mag03kj
LOST
Ok...yes now that you say that.....Thats what it was a vapour recovery! Its still part of the fuel system!
osufans
Central Ohio
x2 on the vacuum leak. Especially since it goes away when you press the gas.
Check your vacuum lines in the general area you hear the hissing.
kjweston
Boca Raton, FL
The hoses coming out of my valves?? I think thats what they are, are both cracked.. the ones that connect to the sides of the airbox. Would this cause a hissing noise? It was pretty bad before so I replaced some pulleys and the belt and it got a little quieter.. but not totally gone. Now its bad again. Granted I do have a ram air on right now but I dont think it should hiss as loud as it does.. btw sorry to slightly thread jack.. but similar problem.
Vtolds
Stowe, VT
I know for certain it is not coming out from under my hood it is in the back of my car. It is not my exhaust. I changed my exhaust because I thought it was and the sound never changed. The suggestion of the vacuum leak makes sense. Which lines should I be looking at? I dont think I will know a vacuum line from any other kinds of lines. So if someone can grab picture of the locations to checks, and what I would need to fix them that would be very helpful.
mag03kj
LOST
It could be want i said!
Jack the damn KJ up and just start the jeep and start looking!
ThunderbirdJunkie
Bronze Supporter
Newport, KY
*sigh*
Check the evap hoses in front of the gas tank above the rear axle.
It's not that hard to pinpoint in most cases.
Ry' N Jen
Go to Harbour Freight and buy yourself a Mechanics stethoscope.
http://www.harborfreight.com/automotive-motorcycle/diagnostics/mechanics-stethoscope-41966.html
They work wonders for finding such little annoying leaks!
Then go over every hose related to vacuum!
ie. Cruise control servo(Vacuum reservoir), Power brake booster, HVAC system,
Emission control system. Check out everything around the intake manifold as well.
Also check the exhaust manifolds.
Either that or take it to a dealership and have them diagnose the problem!
Vtolds
Stowe, VT
Found it. Quick fix, I used electric tape. nana.gif I dont know if that is a good way to fix it, but its working.
Vtolds
Stowe, VT
Electrical tape doesn't fix ANYTHING. Just replace the bloody hose dude. It's like 50 cents a foot.
How does sealing the whole with rubber tape, any worse than replacing it with a cheap rubber hose? Stopped the leak = fixed \\:D/
kjweston
Boca Raton, FL
C'mon man!! gotta use rubber tape and reinforce it with duck tape.. duhhhh :D
no I'd replace the hose.. the tape will begin to leak in a week or two.. I did the same thing on a hose into my EVAP canister.
mag03kj
LOST
Ya i would just go get like 50cent of hose and replace it!
osufans
Central Ohio
was this the EVAP line? TBJ, what kind of hose are you referring to, just vacuum line?
glad to hear you found the cause.
