kmacht
I need some help. I have a 2002 Jeep Liberty Sport with the 3.7 and about 150,000 miles. I was pulling my project truck into the garage using the jeeps hitch tonight. Everything was going fine and the jeep was running good during the day. At one point when moving the truck I shut the jeep off to adjust the tow strap. When I went to re-start it it wouldn't start. The jeep cranks and cranks and will only start if I floor the gas pedal. When it does start it sounds like it is seriously missing and the exhaust has a very strong gas smell to it. If I let off the gas and let it drop below about 2000 rpm the engine sputters and dies. I tried doing the error code self check by turning the ignition switch on and off three times but no codes showed and the check engine light isn't on when I do get it to run. I also checked the battery since I have had electrical gremlins start showing themselves with low voltage. It was at 12.5 volts. Just to make sure I also swapped out the battery with my wifes car. It started and ran the same crappy way. At this point I am stumped. I thought maybe fuel pump or fuel filter but if that was the case it wouldn't run at high rpms and I wouldn't have a gas smell. It is almost like the timing is off. I'm thinking maybe a sensor of some sort but am confused since I thought it would throw an error code with a bad sensor. I'm looking for suggestions on what to try next. Any ideas?
Keith
Keith
