help from electrical people
butcher
Ontario
I'll be installing an OEM light bar on my Liberty,
could not get all the wiring or the switch.
I want to do this without risk of melting wires and causing a fire
went to my local part store and they only had crappy small plastic toggle switches not good for much amps
curious if this would work, it says for LED, but also says for high amps / watts
says its good for 250W
the OEM lamps I believe are 55W and there are 4, so that 220W
comes with a 40A relay, and 30A fuse
but says LED... so that is my concern.
https://www.amazon.ca/Wiring-Harnes...78816662&sr=8-2&keywords=hella+wiring+harness
butcher
Ontario
That one will work without any issues.
The stock bulbs in the Renny lightbar are rated well below 55watts each,more like 27watts each.
Thanks appreciate your input, seems all I can find for wiring harness' are LED.
