heater blower motor or resistor
Ron Burgundy
canada
hello all
I started the KJ this morning and it was a bit cold out so i put the heat on and there was very little coming out of the vents even on 4 so my question is will you alway get air blowing out on #4 if it is the resistor? i have had blower motors go on me before and I have always had warning signs (IE noisy fan or the motor slowing down then speeding back up) its an 04 with 56K on it:shrug:
ridenby
Gold Supporter
Kentucky
Could be the vent door? not working properly.Several posts/threads or this subject.
Ron Burgundy
canada
thanks for the reply i will check that out. also is there a way to test the resistor to find out if that is the problem
valvestem
Northeast US
hello all
If it is the resistor that is kaput, you as a rule will always get the fan to work on the #4 setting. I have not seen anybody say that they did NOT at least have #4. Hope that helps.
Ron Burgundy
canada
it does help but now i am back to step one i guess, the heater motor never made any noises at all, when i turn it on it does not make any noise and i checked the fuse and it is good, i guess i will have to brake and take it to the dealer
