Heat Went Out
kbooneKJ
Holland MI
For some reason my heat just stopped working. I have coolant and the fan works at all speeds but just no heat whatsoever. I hope its not a heater core.... Anybody have an idea?
Billwill
White River, South Africa
There is a post just a few posts below here named "What controls the heat blend door?"
Have a look at that post...it may be relevant to your problem.
ddunk80
florida
could be your temperature controls are stuck. a vacuum or cable operated flapper that closes off the heater core when a/c is in use, or allows cool outside air in. it is under the dash where the air comes out by the passengers feet, sometimes you can move the levers by hand if the cables are stuck
_______________________
Jeep Parts
Direct OE Replacement Parts
