Guy named Sean runs his own little operation called
hemifever tuning. Tunes just about anything Mopar these days. He usually uses SCT or DSP to load custom tunes. He figured out that SCT supports certain p/n PCM's even if the vehicle isn't specifically listed. That's how he figured out to custom tune 3.7's. If you email him your PCM p/n, he can see if it is supported. If it is, you can either get 'canned' style tunes (like a Superchips) or straight custom with upgrades based on your data logs. I wasn't going nuts with the Liberty so I got a set of canned style (87 octane, 93 octane, 93 towing). When I throw that hotter cam in the Ram to with the headers that are going, in, I'll get custom tuning for that. If you intend to get custom cams, bigger injectors, change gears, upgrade torque converter, then you could probably put custom tuning to good use.
