huntbuggy
Got home to start working on the lift, took a breaker bar to 19 lug nuts without issues. Had PB blasted everything last night and again when I got home so figured same routine job, step one wheels off. One nut, however - one of the remaining infamous factory chrome capped ones has caused me a couple hours of grief - soon to become a few more hours I'm afraid.
So here's the tale. 19mm made a pop and grind (as did a couple other capped ones that just popped off) but instead of coming off the cap bent and wedged. With a punch, vice grips and some swearing, it came off. Noticed the open ended lug nut underneath was in rough shape, but did as usual and hammered the 18mm onto it. Forced, no go. Impacted fw/back no go. Forced again with longer bar - and stripped. Tightened an extractor onto it and forced - stripped it almost round. :favorites68:
So without a torch I did like I was taught - start drilling out the stud.
Bad plan. Even with hammer drill am going through bits and am only a third of the way through and it's dinnertime! As I go to the cheaper bits they're wandering and it's a mess.
Few more hours and I think if I don't pull my hair out I'm gonna pay some other sap to burn up bits and swear a bit.
Compassion pls.
p:
Compassion pls.
