Grinding Noise
deknight
California
Whenever I go over a speed bump the front end makes a grinding noise. I am thinking it might just need to be lubed. Has anyone else had this problem? It is most noticeable when it's cold out or when I am just starting out in the morning.
Corwyyn
Southeast of disorder...
(yeahthat)
Go down to your local hardware store and pick up some silicone lubricant (if you don't already have some in your garage) and spray all the bushings - swaybar (under the radiator on the front of the frame), control arms, anything that looks like its rubber. That'll take care of it until winter comes around ;)
IN DEEE
i heard the sound yesterday and again this morning when i went down the dirve way. it happened when i went over a speed bump. it wasnt necessarily a grind sound but like a vibrating grind sound
deknight
California
(yeahthat)
Hey thanks i will try that.
