Gear oil change?
jeeptorino68
Oregon
I recently swapped to 4.10 gears (used set) and was wondering if i should change the oil after a certain number of miles. The gearset was used, but I imagine it is wearing into a new spot so some metal in the oil wouldn't be too unusual?
What are your thoughts.
Cardhu
Great White North
as you stated; Your wear pattern will not be the same as the previous install.
Dump it
JasonJ
Michigan
Why would you NOT change the gear oil? Gear lube is relatively inexpensive and easy to change.
