Gas tank skid issue
mindbomb
California
Trying to remove the trailer hitch for installing the gas tank skid I discovered that the last screw (most forward) on the right side is 100% blocked by the muffler tailpipe. No room to event insert a narrow socket wrench.. Stupid MOPAR instructions show a straight line thru the muffler for the bolt as if its made of air... Tailpipe does not seem to have any removable part/bolt to be able to move it aside..
What gives?
Gyro
Nova Scotia
I used a 2x4 to pry it over enough to get on a short socket on a swivel and long extension.
Or pop off the tailpipe hanger .
Gyro
dude1116
Pompton Plains, NJ
I believe I removed the tailpipe. At the time...I wanted the muffler replaced anyway. Just two bolts and a couple of hangers (one bolt on mine. The other went missing)
jja
Bulgaria
I used a open wrench the first time. You can access the bolt without removing he tire. Less hassle than removing the exhaust. Second time used ratcheting box wrench and that was super easy.
TwoBobsKJ
Northern Ohio
Remove the rear passenger tire and the bolt is right there. Lots of room to swing a ratchet in there to remove it. Or...
Get a 2X4 and push the tailpipe out of the way. Personally I like to stay off the ground as much as possible so removal of the rear tire was my preferred method :waytogo:
mindbomb
California
OKdokie.. I'll lift + remove the rear right wheel, why didn't I see that?
Thanks good people!
