front end clunk, over speed bump - low speed
Mark 01010101
My 2007 Liberty has 140 K ish miles. Had original shocks all the way around. Replaced them with NAPA shocks and struts. Installed, torqued everything. Even replaced and torqued the front sway bar bushings. Upper control arms were replaced by shop couple years back. Only thing I didn't do was replace the sway bar links.
Open both the drivers side and passenger side doors. Jump on door jams. Sounds good/drives fine till I go over a speed bump. Slow speed and I hear noise out of right front end. Clunk noise is best description.
So my thoughts are sway bar links or bad shock or ball joint failing.
Other ideas, thoughts appreciated.
04Roadglide
I had the same issue as you are experiencing. Paid good money at a shop and had the front suspension rebuilt (2004 Liberty 95,000mi.) Brought it home and still had the speed bump clunk. Did some research, here I think, and replaced the sway bar bushings. No more clunk. Not a bad job either. I chose MOOG bushings. They don't slip on super simple but they will go on.
greywolf105
I had the same problem and found it to be loose bolt on one of the upper control arm bushings. Also check the front diff bushings.
Mark 01010101
Thanks for the suggestion. I went with new MOOG bushings. Even torqued them. Worth a try but didn't fix it this time.
Mark 01010101
TY for feedback. Yesterday I replaced the front brake calipers and rotors. Clunk side rotor was worn vs the driver side. Also replaced the sway bar links. Will need to bleed brakes to test drive. Will post results soon.
u2slow
BC
I had a clunk like that.... It was the CV axle banging around in the housing on the passenger side. New CV, intermediate shaft, and bearing/seal was the fix.
Shankster
Durango, Colorado
I've been chasing a similar clunk - replaced everything I could think of but it's still there. To determine if it's something related to the swaybar you can just disconnect both end links and drive around town and see if the clunk is gone - it will narrow your search or eliminate the swaybar or end links as a source.
u2slow
BC
The CV axle clunk is checked with a prybar. How far up can you lever the inboard CV?
Mark 01010101
Sorry for the delay in getting back to you all. I spent the last week taking a hard look at everything in my spare time. Jeep was due for VA state inspection and they are thorough. Inspectors put it on a lift and raised the hood. On lift two mechanics with flashlights went over everything. They passed it and commented that it looks like I had fixed everything that could go wrong. But no help with the pinpointing the squeak. So did my own reinspection. Took the front sway bar bushings off and greased them and reinstalled. They are Duralast Sway Bar Bracket Bushing HB200161 that I bought last month Greased and still had a squeak. Thought these have to be the issue. So bought another set of new sway bar bushings from Moog online. Part #moog-k200161 Installed and problem solved. Who would think Duralast bushings were the problem. Thought the first set I bought were Moog. On the AutoZone web site they were blue. Picked them up and they were black. Wasted a bunch of time on a $25 part. Argh Appreciate all the suggestions. Every one of them.
fastfreddy56
While you are under there, tighten all fasteners that hold the front sway bar mount and sway bar links to take up slack in the rubber isolators. Tighten them even if they don't appear to be loose. Lots of clunking noises will go away after you do this.
Celticlady
Put front on jack stands (on frame-not on lower A frames) so there is about a inch under tire. Use a long crow bar on a 2x4. Pry up on tire. Listen for clunk. Have some else prying as you watch. Should be no play on ball joint. Another way to check for clunk. All wheels on ground. Open front driver/passenger door. Aggressively pull up and down on door.
Also watch sway bar links. These are well known for the clunk. Even on new ones. Get ride of any OEM or any auto parts replacement link. Use these.
100x better. No more clunk. Go to my page here (around 12-27-25) for the installation as they are not for a jeep. It's not plug and play. But not difficult.
