Front Drive shaft- where did I go wrong??
Jo6pak
Left coast of WI
Not a happy camper right now:disgust:
This morning, I finally got around to re-installing my front driveshaft after replacing the TC end CV joint.
Everything seemed to go smoothly on the install. Went for a quick drive down by the airport to test it out in some sandy areas. No more clicking, seemed to engage and disengage with no problems.
Woohoo! Mission accomplished...........until we hit the highway to come back.
At about 60mph, there was BANG! and a vibration that would shake your fillings loose.
I quickly pulled over to the shoulder, stuck our heads under the Jeep and the brand new CV had shredded itself. Luckily, Jon had thought to grab the socket and wrenches, so there we were on the side of I-90 pulling the driveshaft back out. Which was definatley not fun with 18 wheelers whipping by a few feet away and scalding hot exhaust (I've got the burns on my forearms to prove it)
We found the head had come completely off the shaft, obviously shredding the boot and flinging grease all over. The outer circlip fell out in 2 pieces when we pulled the head off. Not sure if this is a cause or an effect.
Here's a pic of the CV.
The splines on the end of the actual shaft seem to look OK
Now, I'm no mechanical whizz, but it seems to me that a CV should last longer than 10 miles. So what did we do wrong?
Is is possible/probable that the new circlip simply failed?
Or could this be caused by not properly indexing the shaft to the flange?
Any other ideas on what type of bonehead error I could have made?
Snail Farmer
Fairmont, MN
I ordered a whole drive shaft for mine instead of just the CV. I haven't taken mine apart so I'm not sure about this at all. But I was wondering if it's possible the actual CV head was installed backwards? Again, not sure if it's directional or if that even matters. Just an idea.
Can't be installed backwards
I would say you didn't have the snap ring completely in place or you have another issue some where
Jo6pak
Left coast of WI
I'm pretty sure the snap ring was seated, but anything is possible I guess
What other issues might there be?
Jo6pak
Left coast of WI
Made in china:happy175::happy175::happy175::happy175::happy175::happy175:
You may be right. I got the head from DriveshaftParts.com as recommended by others on the forum. Is there a better source?
I'm not saying it was an equipment failure (it's entirely possible that I just fkd up) Just looking for answers so I don't get the same result next time
seabass1858
hanover pa stationed in Ft Benning (GA)
seems like it could have possibly binded up somewhere and due to the stress the torque exits at the path of least resistance in your case your cv. when you reassembled was there any dirt particles that could have seized the cv from articulation.
