front bumper removal - metal rivets?
dchadjohnson
Columbia, SC
i need to remove the front bumper to install some front tow hooks, and it looks like my fender flares have metal rivets holding them on, instead of the plastic ones i assumed (and bought to replace them with). before i start mangling the plastic fender flares, is there any easy way to get these metal rivets out?
dchadjohnson
Columbia, SC
Assuming you have a Renegade model those "metal rivets" are fake plastic.
The flairs are mounted the exact same for all KJ's.
it's a 2007 Limited...and they are definitely metal...not sure if someone else replaced them with metal at some point before I bought it. anyway, i've drilled and punched one out, the others are partially drilled out but spinning. ugh, this was supposed to be a quick job but i'll have to finish later.
rjkj2005
US
Why remove the fender flares to remove the bumper. No need they are separated. The bumper cover can come off by itself
dchadjohnson
Columbia, SC
Sent from my XT1585 using Tapatalk[/QUOTE
sorry i mispoke, not the flares...there are 3 rivets in the wheel well that attach to the front bumper cover. i finally got them off and installed the tow hooks -
the rivets were replaced them with much easier plastic rivets.
CinciKJ
Cincinnati
My KJ came with a cracked bumper cover. I am about to order a replacement. I see the 3 mounting rivets in each wheel well. Where else does the bumper cover attach, and what will I need to remove and replace?
Thanks,
Gary
JasonJ
Michigan
Thanks,
Gary
There are a series of screws on the bottom, in/by the air dam. Also need to remove the front grille, which is simple, and there are clips in there. Do a search on here or on Google and you'll see lots of hits with how-to's on removing the front bumper cover.
