Front Bump stops after lift?
Moab
Silver Spring
What are you using after your front end lift?
Which brand does the job right in fit and performance?
I'm at about 3+ inches over stock now. But I'm still using 245/75/16's
Thanks for any help.
ridenby
Gold Supporter
Kentucky
First,you are at three inches over your wore out junk
Second,most use Teraflex bumpstops,they fit,they work.
Moab
Silver Spring
I just put on a set of JBA Adjust-a-Struts and I'm sitting about 22" center of Hub to bottom of front flare.
Thanks for the Terraflex Thumbs up.
osufans
Central Ohio
i just put terraflex on mine...it was harder getting the old ones out than putting the terra's back in.
clean the bump stop bases out after you get the old ones out, then put some soapy water on the new ones and they will just wiggle right in. i did the swap with the tires still on, so i used a scrap 2x4 to apply pressure up against the stops to make sure they were seated, using the tire as a fulcrum point.
