****** Fluid Low?
loves_off_roading
York, PA
I got a transmission flush done about 500 miles ago and I randomly decided to check the fluid level today. It was only slightly above the low circle for the warm mark. I guess this means I should add some?? Also is the ATF+4 at Autozone okay to use or should I get a certain kind of ATF+4?
Dang Jeep guys ripping me off
RageOfFury
Did you check the fluid level with the Jeep on a level surface and the transmission in N?
flair1111
usa
i use valvoline atf+4 iirc. make sure its atf+4 ONLY.
ridenby
Gold Supporter
Kentucky
1.should be hot,just been run
2.level
3.move shifter though the gears,sitting still holding brake
4.put in N.
5.read stick
