I think if you spend the time and money why would you not improve the flow, sound and power that would be the correct way to do it and not restricting the power band like stock,
So the way I see it Tjkj is correct.
But this is only my 2 cents and Im runing a Magnaflow not the loudest but what kick in the power band.
I retract my previous statement, and conclude that going to 2.5" is indeed an improvement.
Not that just going from 2.25" stock to 2.25" high flow wasn't an improvement, because it was, but reading and digesting the opinions in this thread got me thinking about the increased flow of cutting out the reducers in the stock piping and going to 2.5" all the way.
Yesterday I took a ride to Pep Boys, picked up a Thrush welded in 2.5", some clamps and a turn down pipe. Took off the old 2.25" Thrush Turbo, cut the reducer out, and installed the new 2.5" Thrush Welded muffler....
Result.....
Increase in sound quality
Slightly better throttle response
Better power in the low RPM range crawling through soft beach sand
Again, I did see a distinct improvement in performance and mileage with the 2.25" Turbo, so I wouldn't say going that route is a bad thing, but cutting out the stock reducers and going 2.5" is a better improvement....
also replacing the stock tail pipe with a turn down just before the rear axle eliminates a little more back pressure from the bends in that section of pipe.....but check your state MV laws before doing that as it may be a violation......(it's not legal here, but I don't really give a crap)....:smokin:
