ESP/BAS Lights On - Help...
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Haha! Yeah! I was right. You had the same issue I did. Bad alignment!
If it was a wire, relay, pump, or anything of the sort, you'd have had an ABS light as well, along with those other two. Since there was no ABS light, there you go.
long_tall_texan
DFW, TX
Cool. It does make sense when you think about it... Just not what I would have thought at initial face value...
long_tall_texan
DFW, TX
Good Call. Thanks!
jem
pennsylvania
You won't be able to pull a code easily, and none of the store-bought scanners can either.
My guess? Right rear ABS harness. Mine crapped out at....40k miles ;) Look on LOST, other people had theirs crap out too.
I've been meaning to do a How-To with pics, but haven't had a chance yet. Basically, I bought a new end connector kit from Chrysler ($14) and then ran new wiring up into the passenger cabin, under the rear seat, where I spliced into the OEM harness. Cleared it right up.
is there any chance you made a How To yet? mine is doing the same and I am frustrated that I haven't found a youtube or something to fix.
Kickit03
Pa
2010 Jeep Liberty
Hello, I’m new here and had a question. I’m getting a ESP/BAS light and my traction control light is on. Now it’s only periodically. It’ll go out every once in awhile. Then come back on. Any insite?
Thanks,
Scott
long_tall_texan
DFW, TX
Thanks,
Scott
First thing to check is tire pressure. Sometimes a low tire causes enough rolling diameter change to set off those sensors. Next, get an alignment, or at least go get a free alignment check. Last is check the wheel speed sensors.
Not for highway use
NSW, Australia
Wouldn't have a part number by any chance ?? Mines an 05 with just the sensor on the diff
