Long story short I have a 2005 Liberty, engine and ****** died so I got a working one out of a 2006 Liberty swapped the engine, transmission, and the pcm wire harness but now the obd2 says no link and the red light is on. It cranked over about 4 times and died each time than fully stopped cranking and now won’t crank at all. Checked the relays and fuses everything is fine even jump started the starter and it turned so it’s not the engine or starter. Please help if you can. Is the wiring different from 05 to 06? Any help is appreciated.
