Engine stutters when AC is on
SparkyJeb
How can I test my compressor to see if this is causing the issue?
My engine runs strong and my AC blows cold, but when I turn my AC on, the engine stutters.
SparkyJeb
It happens only while idling with AC on. Whether I turn it on while driving or idle.
Ksat
ny
Is the stuttering the result of the RPMs being too low or something else?
Kimuri
man these cars and that a/c pulley is one annoying thing
mine's gotta be fixed too, really curious how much it'll cost me
jeeptorino68
Oregon
Mines doing something similar. Infact when driving you can kind of feel it "engage" also the air is cool....not cold.
Idle speed is steady around 650 without a.c., maybe a touch lower when the compressor runs
Many things to check but start with the AC pulley, bearings, next even the tensioner and related pulleys could be worn out. This little bit more power needed when turning on the AC would cause this . At times the simplest things could be a larger problem. A lot of folks never think of replacing the tensioner and both pulleys ( which can be bought as a set )
