Downstream 02 high disables cruise control?
jeepbeep
US
My 03 Sport 4x4 V6 Auto came with cruise control. It lights up when I click On but does nothing on set, cancel, resume, and coast. My only code is from the downstream sensor being disconnected(it's the high code because it defaults to high). My AC also isn't charged and defaults to defrost vents like it's suppose to. Why could it be that my cruise isn't working?
I've read it can be the clock-spring in the steering column too, but I have no way to test it besides tearing it all down and using a multi-meter; I think.
I guess I'm asking what all disables cruise control?
Royy
Western CO
I'm probably just stating the obvious, but just in case: You have to hold the 'set' button down for a second or so in order for it to set a cruise speed. Just clicking the button doesn't do anything. Cancel/resume/coast only work if a cruise speed is set.
Actually, the AC and the cruise thing sound related. I bet you have a vacuum issue.
TypeRx
Chicagoland
The vacuum line that runs from the cc unit (near the coolant overflow tank) is partially hard plastic and gets brittle. Start by tracing that vacuum line and if broken, simply replace with wiper fluid hose or the like.
My cruise stopped working after I replaced the passenger side valve gasket and even though there were no codes, it was easily traced to the vacuum line.
jeepbeep
US
Looked at mine today. The only line that isn't a big thick SAE hose crimped to metal pipe is that vacuum line(?) on the cruise servo I felt it and it felt good but I'm going to mess with it more tomorrow and probably just put a new SAE hose matching diameter or slightly smaller on it; I think that's what is on wiper tray and sprayers..
The front AC vents and cold air are lower priority because I have a 6 hour trip coming up
teeje
Toledo
When my cruise didn't work it was the brake switch. Cheap part
Sent from my SM-G935P using Tapatalk
teeje
Toledo
Check the t fitting along the fire wall. Sometimes the vacuum line pops off
jeepbeep
US
It was disconnected from the brake booster hose.
It seems this line, brake switch, clock spring, and the actual cruise diaphragm are the fail points. It also fixed AC.
I'm glad it wasn't main harness or clock spring..
Staff online
