Getting ready to install the Steiger Performance window regulator part and have been reading up on the door disassembly and reassembly. There is a water dam or as some call it vapor barrier under the trim panel. Service manual states to make sure it seals good. Is this part normally replaced when disassembled?
I have a BMW and this seal is critical to the door not leaking. If that barrier doesn't seal perfectly the water comes right into the car. Is it the same on the Jeep as well?
