kb0nly
Deleted...
Wait !! How about the wipers they ok ? lol Really i just put some on and all ready failing lolJust finished up the front and rear Diff's today, all the fluids have been changed, all the maintenance is done, ready for winter!!
The front diff was a breeze, the rear was messy but also easy. A 13mm deep well socket works perfect to get inbetween the cover and the gas tank, had it apart in no time. Cleanup took a while as i wasn't going RTV for reassembly and wanted the surfaces clean. New LubeLocker gasket installed, no leakage so far.
Weather slowed me down.. But i got it all done.
Transmission Fluid and Filter
Transfer Case
Belt and Tensioner
Front and Rear Diff
Spark Plugs
All done... And an oil change is coming up. Coolant flush was done with new Radiator last year. I put in fresh fluid for the power steering last fall.
Tires are only one year old now as well...
Shouldn't have anything to do but oil changes for a while now!
Damn... Yeah i need a set of those to!! With all the damn rain lately and the fog in the mornings i wore them out, starting to hop and skip now.
Just a note for next time or any one else
jack up the Jeep from the unibody behind the rear wheels
this will allow the axle to drop and it will be very easy to get past the fuel tank
It was very easy without doing all that.
I don't know why anyone has a problem doing this. I just grabbed a deep well socket and my Craftsman extendable breaker bar for more length. just reached up and put the socket on each bolt and away we went. There is only like three bolts hidden behind the gas tank and it only took me like a few minutes to unbolt the cover.
It would have took FAR longer to jack it up and put in jackstands, and you have to drop it back down to ride height for filling anyway, so i skipped jacking it up and back down, would have taken a lot longer than rolling under there to take those three semi-hidden bolts out! And i'm a fat ass and my KJ is at stock ride height and i had no problem.
