Creaky Front End
Minimike
Fort Frances, ON
Just noticed last night that the left front suspension creaks when it is in motion both directions. I plan on getting the stethoscope out this week and have a listen. I know some possibilities are:
-strut (probably it)
-dry ball joint
-rubber busing
I have had vehicles that had horrible squeaks and it ended up being dry ball joints or it might be time to upgrade those worn out shocks and springs with something a little more liftish :smokin:
Not knowing how many miles you have could be many things
also what lift setup,
first would be the sway bar bushings spray them with silicone spray
second could be weak front SHOCKS and springs
third bad ball joints
top three to check
Jake.Ski
Berlin, NJ.
ill have to see if i can find that over here in germany! I looked at my bushings on my a arms and i saw that it was starting to get some weathering cracks :[
I use Liquid Wrench silicone spray. Works fine, been using it for over a year now...
Minimike
Fort Frances, ON
102,000km so far. I actually have a new set of sway bar to frame bushings, just waiting for some nice weather to put them in. I will put them in tomorrow and report back.
SoonerJeep
OKC, OK
I'll be watching for results. Mine developed a loud creak in the right front last winter. But only when it's cold. It didn't do it all summer and I was hoping it went away. Alas, it's back now that it's in the 30s most mornings.
Lost count of how many KJs I have sprayed silicone spray on the sway bar bushings every fall and it stops the squeak. No need to replace them just spray every oil change and no issues
Its very cheap and easy
Ry' N Jen
Yeah, our sway bar bushings sweak like a well used hourly rented motel room mattres!:D
They're also getting worn a little too much for my liking so I just ordered some new polyurethane swaybar bushings from All J Products last night.
That should take care of it.
Minimike
Fort Frances, ON
Well, just installed the new bushings and presto! no more squeaks. I was kinda hoping for bad struts, wife was supportive of replacing with better ones and new springs (ome). Will have to wait until spring I guess. I know I could have sprayed em but 8 bucks every 100,000km isn't bad for bushings.
Minimike
Fort Frances, ON
yeah I know. Also other news someone wrecked their KJ in the reserve today, They put there 03 on its side. Will probably be a write off from what I hear. We had some good snow fall today.
dude1116
Pompton Plains, NJ
Any procedure I should do? Should I do that when they're extended? Does it matter? Should I clean em up first? I'm gonna do this now...
Minimike
Fort Frances, ON
no, silicon spray does not damage rubber at all. the bushing hold the bar tight to the chassis. The bar tends to twist or spin ever so slightly on the bushings. New bushings grip and twist with it. Old bushings that are worn don't grip so well and the bar spins/twists in the bushing causing a creak or squeak. This slip does not in anyway affect the sway bars performance. The silicon spray simply stops the noise. I replaced them because they were cheaper then silicon spray lol. Only $8. for OEM ones.
