honu
This evening, my daughter mentioned she saw smoke coming from under the hood of our 2002 Liberty. Turns out the "smoke" was actually steam, coming from what appears to be a small crack in the right tank of the radiator, near the upper radiator hose inlet. At first, I thought it might have been the hose, but after letting the engine idle for a few minutes, I could see where the coolant was bubbling out of the tank.
I know that radiators aren't repaired anymore, they're merely replaced, so I thought ask the good folks here if you guys have any aftermarket radiators suggestions, or should I go ahead and replace it with one from MOPAR?
And while I'm asking... not more than 3 weeks ago, I had the cooling system flushed and refilled. The "coolant" leaking from the cracked radiator is a thick, rusty colour. Obviously, there's something wrong here. Can someone take a guess on why the fresh coolant would look so bad in such a short period of time?
Thanks for any ideas you toss my way...
