southernwake
Dropped the KJ off at the dealer to get the coolant system flushed because I didnt have any idea if or when it was ever done and with 119k on it I want to make sure its good to go. They called me and said that they couldnt get the proper flow through the system due to it being gunked up. They guy said it may need new water pump and thermostat etc and the quote was getting up to around $800 for them to fix. I told them to top it off and I would come pick it up.
So my question to you guys is what to do. should i first try to drain the system and fill it up with water and drive it around and drain and repeat a couple times and then see if how it looks. Obviously if it is gunked up I dont want to replace the thermo and water pump and then run the gunk through them.
Then once I do that replace the thermostat and water pump with new ones.
What is the best solution for flushing and cleaning this coolant system??
Currently it doesnt run hot it runs great. It has never gotten above the halfway mark on the dummy gauge. It is always a about the thickness of two of the gauge needles below the halfway mark.
Thanks,
Andrew
Thanks,
Andrew
