Coolant leak
Hockeygoon
Manhattan Kansas
My 2005 is now leaking coolant - on top of all the other issues. I haven't crawled under it yet - haven't had time the last couple of days. Its on the passenger side in the reservoir area - only lower. The heater core hoses are fine and everything that can be seen from top appears dry - anything down low on that side that involves coolant - besides a freeze plug?
Nothing leaking inside and no coolant smell inside - just a small puddle in the garage every morning.
TypeRx
Chicagoland
Look at the lower hose near the thermostat. I had a small leak from that joint. Replaced the hose and clamp and all is well. Also check out the overflow reservoir and make sure the hoses are seated right.
Hockeygoon
Manhattan Kansas
I'll check the lower hose - the overflow tank area is dry - both visually and felt the hoses on it and the hoses leading to the heater core.
If the lower hose leaks - does it run towards the back of the engine?
twowings
Tulsa, OK
The wind is going to push a lot of the liquid towards the back of the engine....
rbtconsultants
pa
The freeze plug on the back of my passenger head was dripping. It dripped down on the exhaust pipe. I couldn't figure out where it was coming from because it is behind the head next to the firewall, right under the coolant reservoir. Eventually and suddenly it went from a drip to a leak and I lost the coolant in the engine, overheated, and dropped a valve.
Don't ignore it.
Hockeygoon
Manhattan Kansas
Don't ignore it.
That explains a couple things. I notice when its being driven there doesn't seem to be much or any puddle - most likely burning off on contact with the hot exhaust pipe. When it sits over night the garage it leaves a mess.
