conduit nuts?
mx3_ryder
troy VT
Stupid question, but what are conduit nuts used for when lifting and where are they installed to gain more height? I read posts about using them just not much detail. Thanks.
Gyro
Nova Scotia
They fit on the bottom of the shock before inserting into clevis.
They give 1/4" lift for each nut,3 nuts max is recommended for a total of 3/4" actual lift.
The 3/8" top plate gives 3/4" actual lift.
Gyro
Gyro
So as to not confuse him
the only top plates that are available are 1/4 inch thick giving 1/2 inch more lift
dude1116
Pompton Plains, NJ
I had 4, 3/16s inches made and sent to me for the full 3/4 inches of lift. If you know someone with some metal working skill you could have them make some out of 3/8 inch steel or the likes.
mx3_ryder
troy VT
Couldn't I just make a 3/8" steel spacer and work the same as the nuts?
CactusJacked
Chicago Suburbs
Yes you can.
For a "spacer": jack up front, loosen the clevis bolt, pry an opening, insert spacer, and clamp it back down.
With conduit nuts: jack up front, drop the lower control arm apart from the ball joint to relieve spring pressure, disconnect clevis from lower spring mount, insert spacer nuts, fight to get the damn clevis and spring mount back together, raise control arm and reconnect lower ball joint.
One way is a lot easier than the other, probably don't have to tell you which. You can also use the spacer as a guide, and remove it once the clevis is clamped down, as it ain't moving. But I would leave it in for reassurance should you smack a good pothole.
EricNorton
Mi
Do I buy the longer kk cast clevis fork and do 2 conduit nuts or is that too much or should I just do conduit nuts if so do I only do 3 max nuts?
just do 3 conduit nuts if you think you just have to have that extra amount
