JBA upper control arm ball joint nut
jrsdoc
Hello folks. I'm installing a new, slightly lifted suspension on my 2005 Liberty, including JBA upper control arms. The instructions call for the upper ball joint nut to be torqued to 81 Nm. However, the portion of the ball joint above the knuckle moves when I tighten the nut. There's no way I can see to secure the portion of the ball joint above the knuckle in order to tighten the nut. Can anyone provide information on how to torque the control arm nut? Any help would be appreciated. Thanks much.
duderz7
Weiser, ID
Carefully put a pry bar in the spring and pry the ball joint firmly into the knuckle.this should provide enough friction to get the nut tight.
jrsdoc
That sound reasonable. Thanks much. I'll give that a try.
I put a small wrench on the very bottom of the ball joint's threaded section below the nut. It has flat sections you can grab with a wrench so you can hold it still. Then I torqued the bolt with a larger regular wrench and used the ol' eyecrometer, since you won't be able to get a socket on the nut this way.
jrsdoc
Thanks for the suggestion. The pry bar in the spring worked to seat the joint into the knuckle and I was able to torque the nut.
Best.
