trichard310
I replaced my clutch recently and now it's worse than the old one. I have grinding/growling noises when clutch is dis-engaged(first thing I noticed). Bad chatter between shifts, mostly in first, reverse, and during downshifts. And a general sloppy feeling(drivetrain feels loose). I also get a clanking noise when at low rpm when engaging and dis-engaging the clutch while moving. Clutch was installed be Cert. mechanic and flywheel was machined.:disgust:
The clutch guy said it is the flywheel, I think its the clutch?:disgust:
Anyone ever hear of changing the dual mass flywheel to a solid mass flywheel?:shrug:
Thanks
Thanks
