Clicking while in 4wd
02kj
spokane wa
After a recent offroad trip my liberty started clicking quite loud in 4wd. 2wd you don't hear it, and it would click while going straight or turning. It didn't have any noises up until this one good size mud hole.
I originally thought it was the driver side cv but it looks good and when i jacked it up and turned it listening for noises its only sound came from the TC side of the drive shaft it seemed (but turning it and listening is quite hard to be exact). Is there any definitive tests to do to see where the noise is coming from so I can replace what is needed.
I agree- the tcase end of the front driveshaft is where the problem is.
CactusJacked
Chicago Suburbs
Mud and water isn't a very good lubricant. If the cv boot is ripped open, which it sometimes is, then slop very likely got inside the joint.
02kj
spokane wa
I got under it yesterday and tried feeling for slop etc but i didnt do the research on it untill later so didnt know to look for the ripped boot, i'll crawl under it and check it out. it didnt have any wierd movement but i also dont have the torque of a t-case twisting on it hah. thanks for the advice.
02kj
spokane wa
haha I got what you ment. I'm just used to bad cv's having some movement or "slop" in them but thats cv axles vs a driveshaft cv.
02kj
spokane wa
Well, it seems that everyone was correct. The boot is definatly torn and in the pic I'm posting you can barely see it but there is a very dry bearing in view. Hopefully this is the clicking I've been hearing, it'd make sense happening right after going through a watery hole. Ordering the replacement tonight or tomorrow and hope to get it done soon, thank you everyone for the help!
Luke
Interloper
Bancroft, Canada
We are all pretty used to that failure around here :D
Good luck .. but you won't need it, easy job and lots of good direction in the How-to
02kj
spokane wa
Well it was very easy. Got done tonight, found out it already had been rebuilt by autopartsunlimited, had their part # on it. I used a driveshaftparts unit this time. Looks like a quality part hope it lasts atleast a while hah
