Chrysler LeBaron Hood Vents*RARE*
slowcrawler
Oklahoma City
I have this set of Chrysler Lebaron hood vents from a late 80s model turbo Lebaron that are used for Jeeps to vent the heat from under the hoods and look awesome installed. I found these while I was rummaging through some stuff. These are very rare to find anywhere. Whats different than most hood vents is that when these are mounted the majority of the vent is recessed in the hood so not alot of it sticking above the hood and you do not have to drill a bunch of rivet holes in your hood, search the internet and you will find write ups and pics everywhere. If mounted right they look factory installed because the vents are actually tappered and follow hood lines. Also pictured are drip pans I fabbed to mount under the vents with hardware for mounting the vents and spacers (not shown). So I took out some of the guess work and expense for you as well. I did not drill any holes in the pans or cut the angle mounts figured best when you go to mount them you can put them where you want. Like I said very rare and they can be mounted on any Jeep...CJ, YJ, TJ, JK, MJ, XJ, ZJ, WJ, KJ's...any jeep. These are gold color. In excellent shape!!! Can be easily painted to match any color.
The more I fab the more I'm intell to start cutting my KJ's hood and then this will turn into a fab link in here, :evil: Asking $80 o.b.o
