Can you mount factory skid plates on a Liberty that didn't come with them?
WesStevens
Hello,
I recently bought a 2006 Liberty as a weekend toy. While at a junkyard, I was lucky enough to find a 2005 with factory tow hooks, skid plates, roof mounted light bar, and tow bar. I grabbed everything I could carry. While removing the plates, I noticed that there appear to be screw in inserts with threads and a hex shaped outer edge. I was immediately concerned that my frame may not have those. I tried to remove them in the junkyard, but I didn't have a hex wrench that big.
When I got home, and looked at my frame, as I suspected, there are only hex shaped stamped holes and not the threaded hex nuts that were in the donor Liberty. So, that questions are,
1. Are these plugs removable? Like, can I unscrew them?
2. Can you buy them new? What are they even called and most importantly can you install these yourself?
or...did I just waste my time spending 3 hours on my back in oil, mud and dirt, under a sketchy KJ balanced on old rims for nothing? :-/
Hopefully these pictures will explain better what I'm asking. You can see the brass colors threaded inserts in the first two pictures of the donor vehicle, on the frame rail and the cross member. The second two pictures are how those same locations look in my frame. Note that I only have the hex shaped holes.
Thank you for any assistance.
Special unique tool required to mount skid plates, it is called a nutsert tool.
This is the best instructions I have for you.
Shankster
Durango, Colorado
On some locations you also have the option of just drilling a hole up through the top of whatever member you're attaching to and installing a long bolt with a nut. I did that where I could and nutserts on the others. I made the mistake of not buying the tool and tried to make my own with a nut and bolt - ended up goofing up one or 2 of the nutsert installs. Once you've rounded the hex hole you're pretty much screwed so be super careful to not allow the nutsert to rotate as you install it. I forget what year the skidplates I bought came off but some of the holes didn't match up (I think it was the trans skid) on my 02 so I either had to use the long bolt method or drill new mounting holes in the skid plate. I've considered welding my goofed up nutserts to the chassis but pretty sure they're stainless steel so that presents some compatibility issues with the carbon steel chassis and the welding rod I have.
Stainless will eat carbon steel if you live anywhere where the roads get salted
WesStevens
Thanks for the input on this. I hadn't considered the long bolt method. That is a great idea and could definitely work for some of these mounting points. I did look into that AVK Nutsert tool and it is priced very reasonable, so I'll probably grab that. Do you recall what size (nutsert) you used? I was about to reach out to them and see if I can order everything all at once.
For what its worth, I got the skid plates from an '05 JK, and intend to install on an '06. I haven't held the skid plates up to my frame yet to line up holes, but they look very close. I guess I'll see.
Thanks again
klc
“It flies like a truck.”
PNW
I bought an engine and fuel tank plate from deadjeep.com and they bolted right up. Fuel plate uses the same bolts as the trailer hitch, you’ll need to remove and replace that if you have one.
WesStevens
I didn’t grab the gas tank skid plate from the donor Liberty yet but am seriously considering it. The Pick Your Part lot has the KJ jacked up/supported by the gas tank skid plate, which makes it impossible to remove as they don’t allow jacks in the yard.
Do you recall if the gas tank skid plate and trailer hitch also rely on Rivnuts in the frame? Thanks
Shankster
Durango, Colorado
Gas tank skid does not require rivnuts. Bolts right up to existing mounting points. I'd grab that gas tank skid if you can - well worth having.
Shankster
Durango, Colorado
Thanks again
Rivnut size I wrote down is M10x1.5x17mm and p/n 06506644AA. You might double check that though.
Shankster
Durango, Colorado
I think I found some generic ones since I didn't want to take out a 2nd mortgage for the Mopar part. It's possible the factory ones fit snugger though but I remember thinking the ones I got were a decent fit.
WesStevens
Thanks again. Ouch, just looked up the original Mopar part you referenced. Dang, they're $8.82 a piece! Now I know what you mean. I'll focus on the generic search.
Shankster
Durango, Colorado
The critical thing will be the hex size - I'd get under your Jeep and measure the holes and make sure whatever nutsert / rivnut you buy matches that. Then you can find the matching bolts. Hopefully you can find galvanized or zinc plated carbon steel - I apparently was only able to find bare steel or stainless steel and I think I went for stainless.
One tip (or lesson learned) from me would be to take a thread tap or chaser and once you have the rivnut installed try to chase the threads. On one of mine at least the bulging process necessary to lock the rivnut in place apparently caused the threads to distort slightly. Then when I tried to bolt the skid in place I got to a point where the bolt bound up in the rivnut and rather than the bolt turning and tightening down the skid plate, the rivnut turned inside the hole and either rounded the hole or the rivnut. Now I have a bolt sticking out on my transfer skid plate with no good way to fix it. I don't know if the thread tap / chaser idea would have been the answer but I wish I had at least tried.
WesStevens
I like the idea of thread tap. I agree that it may or may not help, but certainly won’t hurt! I did find a couple different rivnuts online with the hex shape shaft. Unfortunately, the hex dimension wasn’t included in the item description. Hopefully one of these will be the correct “diameter”. I did measure the hole in the frame, and it is almost exactly 9/16”. I also ordered the install tool and it also comes with M10x1.5 thread pitch rivnuts. So, hopefully one of them will work. I’ve got so many other fun projects going on right now with the KJ that I’m not in a real hurry to get the skid plates installed. I will continue the search if these don’t fit.
Shankster
Durango, Colorado
I guess if you can thread the bolt in with your fingers you should be good to go - if not then go find the tap.
WesStevens
Just a quick update on this and for those interested in doing this project…
I did find a tool on Amazon as well as the correct size Riv-Nuts for significantly cheaper.
Tool:
Rivnuts:
I bought the tool as I thought the longer handles would provide significant leverage and make the install easier. I guess it did…but it was still a bear to install these thing. Especially when you’re laying on your back under the car.
I didn’t get them all in yet…but it is working.
David A. Warr
The front skid plate mounting spots should have threaded holes already. The skid plate for the power take off will need the rivnut inserts. You can install a rivnut with just a bolt and a couple of nuts. It is tough to do upside down on the ground but it is possible. The rivnut might turn in the hole if the hole has got bigger because of rust and stop the rivnut from compressing. That happened to me and I tacked the rivnut to the frame. It then compressed normally.
David A. Warr
blackhawk
Venezuela
Around 8 years ago I bought the mopar rivnut and solded them instead of using the tool I didn't think I needed it.
