Camshaft Position Sensor
Logan Savage
WV
Can the camshaft position sensor cause only one injector not to fire ?
teeje
Toledo
No. The camshaft position sensor only pays attention the the camshaft position. Hence the term camshaft position sensor. It's possible for injectors to short over time. Try hooking up a multimeter and see what the resistance is on a known good one and check the bad one
Logan Savage
WV
According to what I read the camshaft position sensor sends a signal to the PCM at the appropriate time for the PCM to send a signal to the appropriate injector & that injector fires . If that is correct , if for some reason the camshaft position sensor skips sending a signal for # 4 injector then # 4 injector wouldn't fire .
I'm kind of grasping at straws , I have verified power to one of the injector wires , I have verified continuity of the other injector wire to the PCM . There is power to the injector all the time & the PCM is supposed to provide a pulsing ground to the injector to fire it . The PCM requires a signal from the camshaft position sensor before it provides the ground . At least that's the way I understand it .
I know the injector is good , I know the power wire is providing power to the injector & I know the ground wire from the injector to the PCM is good . The PCM is not providing the ground so either the PCM isn't getting a signal from the camshaft position sensor or the PCM itself is bad . I'm trying to eliminate the possibility that the camshaft position sensor could be the culprit before I condemn the PCM .
the cps is not that expensive to replace. I think it's only a $20-$30 dollar MOPAR part if memory serves me correctly.
kage860
Westchester, NY
I'm assuming you have a missfire in cylinder #4.
Have you tried to swap the coil / spark plug to another cylinder yet?
While you have it out see if spark plug #4 is soaked in fuel or not.
After that I would look at the injector, then the CPS last based on your symptoms. Usually with a bad CPS your car won't start.
Logan Savage
WV
Injector # 4 isn't firing . A noid light won't flash when connected to the connector of # 4 injector . The light flashes when connected to other injectors . As previously stated I have verified power on one wire at the connector & verified continuity of the other wire from the injector connector to the PCM . It seems unlikely that the camshaft position sensor would skip one cylinder only but I'm trying to find out if it's possible . I guess I'm hoping it isn't the PCM but more than likely it is .
teeje
Toledo
Sorry you're correct. I was thinking of something else. Yes the cps sends a signal to the injector when the correct valve is open. However, these 3.7s were known for bad valve seats. I had the same issue. Let me guess. P0304? That's exactly what I got before I got a new engine. Run some marvel mystery oil in the tank but make sure to read the directions. May free up some carbon. If you haven't swapped the "bad" injector with a good one yet, start from there
