Bumpstops
snickersbaby5
Illinois
I am installing the OME/Bilstein combo and I am just wondering if bump stops are needed?
I guess my question is can I go back at a later date and put them on?
jeeplib05
Ohio
Much easier to just throw them on while you have the rear taken apart
It takes all of 5 mins to drill the holes and tighten them to the lower spring perch so I'd do it now
Make sure to use two for each side (one per inch of lift)
Yes you do need them from the get go, if not you may blow one or more of the shocks
