I got these from Amazon USA. Today. 12-27-25
Spent the afternoon fitting them.
They are not for a liberty, but will work. One stud is much longer than the other. The stud is short. You will have to remove the installed washer to get a least one thread past the locknut. The other you will need to stack washers.
The stud is 13mm. The hole is probably worn. It's not 14mm. Its just a sloppy 13.
You will need to check travel at full extend ( full right & left) to make sure you are not hitting your abs signal wire. I had to relocate and secure the wire higher on the hub.
I ended adjusting the link turnbuckle to center to center of 6".
And I have always had inference between the sway bar and tie-rod end. Now it's worse with lift. Especially with the larger articulation cv joints. I had to grind a bit on the sway bar. Probably took off about 3/16" on each side. I did NOT grind on the tie-rod.
There is not a lot of clearance on these liberties.
