Bad heating issue (sorry for another thread!)
mx3_ryder
troy VT
I don't want to hijack this thread but, I have a somewhat similar situation. My heater works fine until I get to a stoplight (or anywhere else it's just idling) and it immediately turns cold... Any thoughts on what the cause is?
Same problem I have with my Accord. How cold is it there?
Counting My Blessings
Does it keep the heat going alright if you give it a little gas and keep the engine RPMs up? If that's the case I might suspect a water pump.
(I am an Instant Expert™ since I just did mine over the weekend.) ;)
I would get a second opinion before diving in - it might be something simpler. I was being a little tongue-in-cheek with my "Instant Expert™ " crack.
If you do need to change it, here you go:
[YT]j9xCAXg9-5s[/YT]
I am mechanically inclined but had little experience with motor vehicles. If that video looks doable to you and you have a good socket set and torque wrench it is a simple job. I had a few problems, but they were mostly due to bad luck. I tried to replace the thermostat while I was at it and got a dud, then had the O-Ring on the radiator draincock fail. Neither was expensive but were a pain in the butt when working outside in 10-degree weather.
Play-by-play here:
http://www.jeepkj.com/forum/f196/water-pumps-n00bs-57502/
Like I said, I'd hold out for a second opinion before you start ripping parts off. The water pump cost me $50, so that part isn't bad. Make sure you use HOAT coolant ONLY, though, or you'll be doing it again before you want to. :)
You can use the Zerex G-05, too. It's about ten buck a gallon cheaper and is available at NAPA. There is a list of about a dozen certified brands floating around here somewhere but I'll be danged if I can find it.
Low coolant can cause this too. Been there. I'd check that first, then go with the WP.
