ATF+4 Fluid Protectionism?
Discussion in 'KJ General Discussion' started by LibertyTC, Mar 15, 2010.
  1. Lancer
    Lancer Full Access Member
    287
    Mar 22, 2008
    South East London
    Fairy nuff! Thanks!
  2. belvedere
    belvedere Full Access Member
    547
    Oct 23, 2008
    SD
    Any approved (on the list) ATF+4 is essentially the same stuff. Buy according to price.
  3. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    6,694
    228
    Thanks, I did find The Mobil Super ATF+4 at Can Tire which also was available for $8 per Litre, and will use this for the front transfer case.
  4. ptsb5a
    ptsb5a Full Access Member
    2,446
    Mar 29, 2006
    Northern Alberta, Canada
    Front transfer case? You got two? Kept a franco from putting ATF in the diffs on his truck the other day. In french anything with gears in it qualifies as a transfer case. Poor dude, would've hated to see how long his diffs would last with ATF in them!
  5. TAwesome
    TAwesome Pizza Pimp
    349
    May 16, 2010
    Grand Rapids, MI
    Wow good catch on that fatal mistake!!!!!
  6. JeepJeepster
    JeepJeepster Full Access Member
    8,409
    Dec 15, 2004
    Same here.. Cant find the stuff anywhere anymore. Not sure what happened to it.
  7. jeepin06
    jeepin06 New Member
    Sep 18, 2010
    Kentucky
    Glad I found this thread. I'm more of a LOST member but I'm going to start using this site more. In a few weeks I'm going to have the Jeep dealership service my T-case and tranny. I'll just let them use the fluids they use. :shrug:
  8. tjkj2002
    tjkj2002 Full Access Member
    10,614
    Dec 17, 2006
    A Jeep dealership will automatically use the correct fluid,besides the 247/249 t-case they will only put ATF+4 in a t-case.
  9. Okura_hubby
    Okura_hubby Full Access Member
    154
    Sep 8, 2011
    north carolina
    I was reading my Jeep Owners Manual. And seeing what it said specifics in regards to ATF+4 stuff
    Page 338 of manual says Using transmission fluid other than the manufacturer’s recommended fluid may cause deterioration in transmission shift quality and/or torque converter shudder. Using a transmission fluid other than the manufacturer’s recommended fluid will result in a more frequent fluid and filter changes.. Refer to Fluids, Lubricants, and Genuine Parts for correct fluid type.
    On page 362-363 it states for Engine Oil to use API Certified SAE 5W30… but for Auto Trans fluid it states Mopar ATF+4 Automatic Trans Fluid. (no substitute, by name specific).. But upon calling Jeep's 1800 helpline, and speaking to local Jeep Service Dept any ATF that meets or exceeds ATF+4 is authorized. (to include Royal Purple MaxATF)
  10. Jake.Ski
    Jake.Ski Full Access Member
    249
    Jun 19, 2011
    Berlin, NJ.
    Sp the royal purple MaxATF is good to run, because i cant find any other ATF over here. Atleast not on 2 bases... But i can find the purple.
  11. BjBnet
    BjBnet Full Access Member
    614
    Oct 21, 2008
    Ottawa, Ontario, Canada
    I bought some Castrol ATF+4 last year at either Walmart or Canadian Tire... pretty sure it was CTC though cause I normally stay away from Wally World.
  12. Jake.Ski
    249
    Jun 19, 2011
    Berlin, NJ.
    Royal Purple Max atf? Can it be used? I know that its not on the list, but thats what the mechanic here in Germany recommended because ATF+4 can't be found in Germany...
  13. tjkj2002
    10,614
    Dec 17, 2006
    No it will not work.Any Chrysler dealership will have the correct ATF+4 and I now they are over there.
  14. Jake.Ski
    249
    Jun 19, 2011
    Berlin, NJ.
    I don't want to sound like im beating a dead horse but the RP website says that it covers ATF+4. All I hear is great things about it. I just don't understand.
  15. tjkj2002
    10,614
    Dec 17, 2006
    They also say it covers DEXIII which in GM trans does not like friction modifiers that is needed for ATF+4.Plus they state do not use in place of Ford's type F ATF which has a heavy does of friction modifiers like ATF+4.
  16. ridenby
    ridenby Gold Supporter
    4,289
    Apr 19, 2009
    Kentucky
    They are selling a product,do you think a certain toothpaste will get you laid?? P.T.Barnum said there was a sucker born every minute,he sold stuff too.
