Actual Lift Amount - Lets Compare Fender Heights
linewarbr
Baton Rouge, LA/ Port Neches TX
06 CRD Sport.
Lift installed at ~75,000 miles, all with original suspension.
Before:
DS Front: 18"
PS Front: 18.5"
DS Rear: 18.5"
PS Rear: 18.5"
After:
DS Front: 21.25"
PS Front: 21.25"
DS Rear: 21.5"
PS Rear: 21.5"
Did the Jeepin By Al's Adjust-A-Strut Lift. I haven't measured it recently, but if it has sagged any I'll just adjust the collars to get it evened out again.
KornyBrad
NW, MO
2002 KJ Renegade
85k
Front- 18 ½
Back- 18 7/8
All stock for now.
Planning a WesWay lift soon.
calamaridog
Vegas
I guess I'd like to see how much ground clearance the various combinations are getting you; measured under the front skid plate and rear differential would be a start.
Lift doesn't change that much, only tire height does so those with taller tires will be way higher of course
Mine front under skid plate ( lowest point) ...13 1/2 or right about there
rear under the lowest point of rear diff.....9 5/8 or so
I hope you know I had to go out and crawl underneath to get these for you!:happy175:
colinmacdon
Regina, SK, Canada
Well it will for the front as the taller springs will push the arms down raising the clearance under the front diff. Extreme example is the VW Touaregs with independent air suspension that car raise clearance by 5 inches...
calamaridog
Vegas
The old double edged sword huh. More lift needed for more tire!
I have OME 927/948 and 245 75r16 tires.
10" under front skid and 8.5" under rear diff:shrug:
Thanks for checking!
KornyBrad
NW, MO
2002 KJ Renegade
85k
Front- 18 ½
Back- 18 7/8
All stock for now.
Front:
20 1/8 driver
19 7/8 pass
Rear:
20 5/8 driver
20 3/8 pass
Added 3/8" Boiler shim and clevis lift in front, 2 extra isolators in back.
Got about 2k on the OME/Bilsteins...I'm at 21 1/4" all the way around.
Almost 10,000 on my version of a OME lift
front (I dropped it down recently) now 23 5/8
rear ( with the new never before used, I don't think, on a KJ shocks ) 23.75:icon_twisted::icon_twisted:
badkittystt
St. Thomas, USVI
I did a quick measurement today and got about 17" all around. Mr. Darcy is just over 32,000 miles but those are rough island miles and spent his life until November 10 being a rental car. I'm seriously considering upgrading but I honestly don't know what I would upgrade :shrug:
Now that he's with me his life will be rougher, but a hell of a lot more fun!
long_tall_texan
DFW, TX
Sounds like you are sagged about 2" all around from stock height. Replacing with OME springs all around and new shocks would greatly improve your ride.
yosemite.kj
u.s.a.
2007 white liberty sport with 86,000 miles, half inch clevis lift, nothing added to the rear.
245/70R16's with minor rubbing on front of the front fender, none on pich weld.
Fender heights:
front 19.50
rear 18.75
Fender heights:
front 19.50
rear 18.75
Well at least you got the front back up to just above stock height :whip:
