What's acceptable for spring sag on a KJ?
slingworks
I've kinda noticed a bit of front sagging on my 05 Liberty. It's one of those things that's kinda crept up lately, but didn't really notice until today.
What made me notice it was a quick look at the suspension, not much travel left! LOL
When I came home I measured it out, and front is 17-1/4 from the center of the CV to the flat underside of the fender flares. Rear sits at 18. (I changed rear shocks recently).
I don't remember when I last changed the front shocks, maybe 30k miles ago, but I drive lots of rough/gravel.
I kinda scrolled the net and some past topics here on the forum, but found things a bit conflicting. I did come across a measurement of 19" center hub to fender flare underside. Am I really sagging that badly or is that a measurement for the 2002 Liberty that was a bit higher?
Also, I looked at some shocks around and I see the market is flooded with cheap shock assemblies. $100 a pair for China's finest. I'd normally laugh at the thought, but I'm wondering if I could get 20k miles out of a set of those....I usually buy Monroe shocks, but the last pair I bought were "Assembled in China". Really left me wondering if I was just buying the same Chinese made shock assemblies everyone else sells with a premium "Monroe" sticker attached??
As an afterthought, i wonder if it's possible to attain a 2002 model "height". IF I had a bit more, think it would help dampen the ride in any extra way? Just wondering.
Yes, I think KJ's were 19" from the center of the wheel to the fender flare in the front end. That means your springs are sagged 1-3/4"! Whoa.
You'll need a spring replacement to regain height and functionality. It would be best to replace the shocks at the same time, as old shocks run on sagged springs are probably toast as well.
To get another half inch, which is about what the early model 2002's had, you could do a clevis lift for free or exchange your KJ clevis (strut forks) with KK ones, which are supposedly a little taller. Of course as soon as you change the geometry you will need to get an alignment, so nothing is actually free.
slingworks
None! LOL. Upgrade due for sure.
Oh come on, nobody is perfect! :) Today I ordered a pair of Monroe's that come complete w springs/mounts and a set of "Moog" rear springs. I could have maybe gotten by with just fronts...but didn't want to risk the back end sitting lower than the front. Nose down seems more acceptable? LOL.
I just put new tires on it (10ply) and I could by tell the way they rode, they had way too much air in them. Was somewhere north of 60lbs. When I let them down to 28 yesterday, I'd swear it sits lower still....
Got a little ambitious and bought a set of used tow hooks on Ebay as well....Might actually use them someday?
slingworks
Ok, so a little update:
I installed some Monroe quickstruts (The pre-assembled deals with springs and busings/mount) in the front and a set of Moog springs on the back. Feels better, and maybe a little improved height, but not much. Measures at 17 1/2" from bottom of the plastic flare to center of the cv. Rear measures around 18". That's still quite a bit away from the 19" I keep reading/hearing about??
I'm measuring from center of the CV Axle to the bottom outer edge of the plastic flare.
I'm going to leave it like this, rides decently. Surprised it's only slightly improved height wise?
Ian Glass
Hi Slingworks,
I played around with the front end of my KJ and I found the following as the front end was way too low: the lift effect of a spacer on the front struts is 1.8:1 (19mm spacer gives 34mm at the wheel). My Jeep was way too low measuring 436 -the same way as you measured! After fitting the 19mm spacer the height increased to 470mm. The spacer can be fitted without removing the front Struts for the Jeep. I have the procedure written out and if you would like it I can mail it to you. Please mail me on [email protected] and I'll scan and mail it to you?
Spacer dimensions - OD 60mm X ID 56.5mm X 19mm high (Spacer effect).
After fitting the spacer at the front my Jeep is now sitting level and the front end has much better clearance when going offroad. Back end measured 470mm.
Good luck playing with your KJ!
