ABS light on...I dont have abs...
That's interesting, yet strange. Why is it throwing a code?
Try a hard re-set.
Take both battery terminals off & tape or clamp them together for 50 minutes, isolated away from battery.
Re- connect terminals to battery. Does that fix the ABS light from coming on?
Nicodemus Arceneaux
Try a hard re-set.
Re- connect termianls to battery. Does that fix the ABS light from coming on?
about to try that, will report back..
Nicodemus Arceneaux
Try a hard re-set.
no luck there... i have previously replaced the rear diff VSS/"ABS" sensor and harness (the closest thing i have to "ABS")..
Nicodemus Arceneaux
That's where I would start. I dug around a bit and that is the only thing connected to the ABS MIL.
I have already replaced both the sensor and harness. all readings are accurate at the VSS/ABS sensor, and I have speedometer function. I'm stumped... been pouring over service manual but there isn't any clear directions to look for next.
What I don't get is my Libby doesn't have ABS at all.. How's it throwing a light if there's no computer installed.. in theory shouldn't this light not even operate after cluster check? Perhaps it's a ghost of my Cherokee long dead....
Just hangin' out.
Time for a code reader!
What kind of scanner are you using? Try a shop scanner...
Can you confirm your Brake block looks exactly like this?
Someone with a good shop scanner like Snap on Ultra, should be able check for any dash communications errors.
Could it still have a stored ABS code? Or some other brake error? This is just too strange.
Nicodemus Arceneaux
I’m at work right now but yes that matches my brake block
Wait.. the instrument has been replaced by previous owner. Could that be the issue? Is there a way to relearn the cluster?
Cluster replaced ok then...there are different series of clusters.
My 2004 Canadian import for instance is type 33, what does your read as?
Ok..Help..
Can anyone else with a 2002 kJ in MPH help to confirm that type 35 is the correct cluster on theirs as well?
We sure have come full circle now, with no resolution.
Suddenly a small piece of electrical tape over the ABS light sounds like a good inexpensive repair. ;)
I'm trying to imagine what the dealer would charge to diagnose this most unusual situation.
Billwill
White River, South Africa
Page 8J-7 of the 2002 Jeep KJ Service manual states....."When the vehicle does not have this equipment (ABS) a DBRIII Scantool must be used to disable the erroneous indicator"
In other words the Dealer's DBRIII Scantool must be used!
Edited to insert "does not"
