deknight
Well I have another "Is this normal" type question. It seems when it rains, it pours. I started using my a/c today and I noticed from the sounds under the hood, that it seemed to kick on then off then on then off about every 10 seconds. Meanwhile it continued to blow cold air with no problem. When I got home, I looked under the hood and I noticed that everytime I manually reved the engine I noticed that the a/c clutch wheel (or whatever the inner wheel that spins on the compresser is called...) would stop spinning and appear to lock up! It will start spinning again if i continue to rev the engine but never in the same intervals, sometimes 5 seconds later, sometimes 3 etc. If I imediately let off the throttle and rev it again it starts to spin again. Is my compressor going bad now also? Or is this normal? Oh yeah the car will also shake a little when the compressor starts back up again. I really notice it when I am at a stop light and the thing is just idling. I never noticed this before. Thanks!
