A/C Compressor Clutch Fuse No Power
sebastians
So i have been having issues with my A/C not working and I did the little trick that when you flick the key to the on position 3 times it shows what DTC's there are stored. I got the code P0645 and I checked the relay to see if it was getting 12 volt constant, 12 volt while in on position, and if there was ground while the engine was running and they were all good. I took a multimeter to the actual compressor itself and that was getting power but the clutch fuse is getting no power at all. I have a 2003 KJ with the 3.7
CheddarGau
Lower Mainland BC
Did you check for power with the vehicles running and AC set to on when it had no power? Mainly just making sure you have the right conditions for testing :)
