A a-arm ?s from my experience.
Cardhu
Great White North
is this a generic sheet that i can just give them?
Its my alignment sheet from my last alignment.
More for your back pocket when the say that they can't do it after trying for 5 minutes.
the specified range numbers are on every alignment machine. My lift puts me at 21.75 - 22 inches wheel center to fender with all the stuff in my sig. Assuming similar setup it should work for you.
Cardhu
Great White North
okay thanks! i ll give them a starting point to try and hit.
As noted before camber -0.4 first. Caster as much as possible with cross caster <0.5. Between 2 and 3 is where it will end up depending on lift. Anybody can set toe.
Ends up giveing you pretty quick steering which takes some getting used to on the highway again but super easy steering effort at low speed.
It was a noticable change from stock alignment handling.
mightybeet
connecticut
i said make this and this is what they did. they said the LF camber was maxed out. steering is a lot better. tire rotation was a big help. noisy tire is now in the back. now i can sleep when i drive. little vibration at 60+ but i planning to do some front end work soon.
lift info:
front 21.25 - 21.5
rear 21 - 21.25
wheeee32
Not the mountains.
I'm gonna have to save that sheet for the next alignment. I'm about due for one. I love my Duratracs.:icon_lol:
dude1116
Pompton Plains, NJ
So this is without A-Arms. What are everyone's thoughts if you don't mind me asking? Caster seems a little low and thrust angle seems a bit too out of whack for some reason (nothing I can do about it). Drives pretty well though!!
