30000 miles, a good start for my journal
hyde
52707 Miles
September 26, 2008
Radiator is cracked again, second time in 10 months. Went back to the dealer, they honored the 1 year Mopar Warranty (thanks Blake for reminding me), and it was replaced under warranty.
Belated oil change has been performed (4200 miles).
hyde
- New Wiper Blades after about 1 year, this time Michelin didn't have them in stock, I had to go with squeaky RainX. I don't really like them.
- All three brake lights went dead on me! Damn.. Just replaced one, others pending. How could they all die at the same time.
- Garage is done, now I can tuck my jeep in. Door opener was installed yesterday.
- I am overdue for state inspection.
hyde
54500 miles.
Air Filter $7
Quick Splices $6
2xBulb 912 $3.79
Prestone Fuel Injector & Engine Cleaner $7.49
hyde
55555 miles
Water Pump blew, got the Jeep towed to the dealer, it was fixed under warranty with $100 deductible, deducted from the wallet.
Update:
hyde
As good as that may look, I just cannot trust the adhesives, especially with high temperature changes like in NY (110+ in summer and 0 in winter)...
hyde
Oil Change at 57,000
Battery at 58,500 Finally replaced the OEM battery with AC Delco 60 Series ACD34-60 (685 CCA) @ $120 including terminals cleand up.
Brakes are shaky, inspection states rotors have lips and are slightly warped. Quoted $458 for both front and rear pads/rotors replaced with Bendix brand parts.
Transmission service is due within 2000miles, I should also look into spark plugs & replacing the belt.
black snow
Saskatoon, SK, Canada
@hyedipin
Can you list the lights/bulbs you used on your KJ?
Am in the process of getting the bulbs and I would like to chnge all lightings inside the jeep. The dome light, instrument panel and the lights on the cargo area and just want to be sure I got the correct part.
I am seeing T5. T8 and T10 on those LED part number I suppose.. or 194/168. Would they fit the OEM bulbs receptacle?
hyde
black snow, sorry I didn't see your question before. I did not replace any lights inside the cabin, everything is stock.
I did find some lights on ebay before, they listed "Part Numbers 579, 579, 211-2, 212-2, 214-2." I have no idea what these mean, but there are some replacement dome lights on ebay.
hyde
Just rolled 60,000 miles.
Finally ordered:
Item Description Ship Qty B/O Qty Price Amount
500MRPF300 Alpine MRP-F300 50W x 4 Multi Channel Power Amp (150W Bridged)
575P2L110 Rockford Fosgate P2L-110 Stage 2 10" Hatchback Subwoofer
142PA8 EFX Amplifier Wiring Kit 8-gauge w/Patch Cord
I paid less than this since I had credit.
hyde
not with the blown speaker (Part No. 56038593AH), which I am not going to pay $50 (used-ebay) $130 (new) or $230 (dealer) for!
The plan is to try to repair the door speaker, if all fails, just use the 2 available channels on amp and wire new speakers to it.
hyde
Installed the amp & the subwoofer last night - 06/23/2009. Pictures to follow.
I am out of Bleache White tire cleaner, time to get a new one.
Wow, i did not know that I had a lot of junk in the cargo area.. Why do I need three umbrellas, little used wiper blades, 5 pairs of booties, what seemed to be a bag full of bags, a huge tape measure and a tiny tape measure, 5 pairs of construction gloves, rolled up wall calender in a tight case that makes it look like a big stick, no parking sign, spare eyeglasses, a knife in a case that somehow broke in half at the handle, and bunch of other stuff in another bag that I haven't checked yet. All came out of the duffel bag there, these are all in addition to the stuff I regularly use and need, like a first aid box, screw driver set, wrenches matching frequently used nuts, windshield shade, duster and a can of stoner invisible glass.
So how does it work??
By the way, that Stoner invisible glass is awesome. Just throw the rest of the stuff away.....haha
hyde
Hey Dave, It works good.. nice and loud, and I never thought I would tone it down a bit on certain songs.. but I find myself lowering it sometimes, thinking it won't handle it or blow it..
hyde
07/23/2009, 61250 Miles
-Four new Bendix rotors, new brake pads, brake fluid, etc,.
-Tune Up,, air filter, lube, Ignition and Fuel Service, New Champion Iridium Spark Plugs
-Castrol Syntethic Oil Change 5W30
-Mechanic spotted leak on front differential, main seal needs to be replaced, it is strange that this could happen since I had front diff serviced about 15k ago.
-Need to get transmission service performed, as it was due on 60k
hyde
Terrible vibration on steering wheel when brakes applied, called back scheduled to replace rotors
7/25/2009
Front rotors were defective causing the vibration, probably warped, S.O.B.s. Went back and they replaced it. The guy also fixed the little chiming noise I had somehere between front wheels, no more chiming now.
