2011 Severe Duty Cooling
pastorjeep
We just replaced my sons 1997 Wrangler with this 2011 Lib. I got it cheap with a blown water pump and dropped exhaust valve seat on cylinder #1. My son goes to college in Lakeland Fl. while we live in NC. Neither place is known for cold weather, :) since he is often sitting in traffic on I-4 I am considering adding a mechanical fan to this while putting it back together. What is everyone's experience with this "upgrade". Is the loss of mileage and power worth it or is the E fan good enough on a well functioning cooling system? The Jeep on has 115K miles and is in really nice condition. The other question I have is on the sun roof. It doesn't look like it os leaking and I am scared to even try opening it after reading the horror stories. Are they really that bad? Thanks!
I 100% think the mechanical fan is worth it. I installed one on mine and the cooling has never had an issue since. Also, transmission temperatures are lower, which will make the transmission live longer. The aux fan is also the main add on of the tow package, besides the hitch and trailer wiring.
No real impact on mpg that I noticed. It does whoosh for the first minute or so after turning the Jeep on, then quiets down. When the under hood temperatures clime, it will turn on and you’ll hear that whoosh and know it’s working.
pastorjeep
That is good to know. Most people claim a loss of 1.5-2mpg. He is stuck in Orlando traffic all the time and it is over 85 degrees most of the year there.
I'm not as well versed on the KK's, but the 2 speed electric fan on my 04 was more than capable of keeping the engine cool. I only added the mechanical fan so it had a backup if/when it fails. Having a bit of redundancy makes me feel better.
With the 'stock replacement' fan clutch, the fan never engages but it does keep the engine below the temp at which the electric fan kicks on (217F on my KJ).
If you get a severe duty clutch, you may lose 1-2mpg.
MonteF
I have a '02 with the factory heavy duty cooling and tow package. It is tight with both fans in there, making it hard to replace the A/C compressor and radiator. Ask me how I know and it was not at the same time. Also getting to the oil pressure sending unit is a tough reach from below. It never overheats though.
ebgasolinedream024
One item you might want to at least be aware of is that if the water pump impeller or the seal or whatever it was fails (mine did, a 4 year old Mopar unit) that fan becomes a berserker in the engine bay. When my water pump failed that secondary fan took out the electrical fan and damaged the Fan connector. I purchased an AISIN WPCH601V to replace the Mopar unit and a new Dorman fan to attach to the water pump (I do like the extra cooling option).
Another variable is that the Jeep’s radiator not only contains the engine coolant, but it also has the stock transmission cooler integrated into it. By having extra HD cooling, you are probably also increasing the life of your transmission, especially if you tow or live in a city or mountainous area.
pastorjeep
Eb, that is true. I didn't think about the secondary effects of a failed water pump with the fan hanging on it. As for the trans cooler I already installed a external cooler. But maybe it will still help the trans.
burntkat
I am running a flex fan and fan clutch eliminator....ie, a hunk of aluminum between the WP and the flex fan.
It is THE BEST cooling mod I've done on any vehicle. Yes it is louder, especially on the KJ (and probably the KK), because of the electric fan moving CW and the flex fan moving CCW. That turbid air makes noise. So what? It's a Jeep, not a Cadillac.
I have driven in 100 degree heat with not a single worry about the engine. At the time I had no AC, so it was miserable.
burntkat
FWIW, I haven't noticed an impact on mileage. It got crappy mileage before, and after. I average about 10mpg.... But then I drive it like I stole it.
burntkat
This is the exact same problem you'd have with the factory fan clutch. They both attach to the nose of the WP.
Thia concern is much ado about nothing. It's a wash either way.
burntkat
If you REALLY want to go nuts... And don't live in an area that gets a lot of snow... Bypass the in-tank ****** cooler and put the biggest RV ****** cooler you can fit, in front of the radiator. Or go really nuts and plumb it in after the return of the ****** cooler in the radiator.
This is my default build in anything I own that has a slushbox.
I understand it works well in the cold areas, too, but it might over cool the ******. I have no experience there....
EDIT - stupid filter. The stars are the word 't r a n n y'. Ridiculous nonsense...
pastorjeep
Ok, got the the new head gaskets on and have been driving it for a few days. I have not installed the clutch fan yet. I want to drive it for a couple weeks and put a few hundred miles on it. Right now I keep the scan tool hooked up while driving. Tomorrow I am changing the oil and flushing the trans with fresh ATF +4. The engine temp while driving stays around 197-199 and when sitting at idle for a while it goes to 203-205 and with AC on it goes to 212-217 at highest so far. The scan tool shows a trans temp of 175-185. Even though the engine temp is not "over heating" the engine seems extremely hot. When I pop the hood I et a blast of hot air. Where does the engine temp sensor pick up the reading and could it be lying to me. Or am I just paranoid because I jsy got done replacing head gaskets? :rolleyes:
