3.7 2005 no fuel
Japser007
Netherlands
Hi!
Yesterday I started my jeep just like every day. I started riding and released the pedal for a speed bump.. and the engine failed. I tried to restart it but I didnt start again. The starter was working fine just like everything else exept that I wouldnt fire up.
Today I changed the ckp and csp sensors. No result..
(crankcase position sensor & camshaft sensor)
I have got power on fuel fuse #14 (10amp) and #24 (20amp under the hood). Also the fuel relay “clicks” when you put ignition on. Also the ASD relay clicks.
I have spark.
There i no noise from the fuel pump when i put on the ignition.
Someone any suggestions?
Thanks!!
JasonJ
Michigan
Jasper, this "Electronics" section is for vehicle electronics such as lights, radio, and accessories... you may get more views and more help by posting this in the General KJ section.
It sounds like you've traced power appropriately, you may be looking at a failed fuel pump module.
