2012 Rear end noises ???
Katmandu
Troy, Ohio
Ever since my 2012 was brand new, we've had gear whine while coasting. I now some gear whine is normal and not harmful, but when is too much ?
Also, recently we've noticed on (2) separate occasions while driving real slow (under 10MPH) the rear end made a loud clunking noise and felt a "bump" at the same time.
I'm more concerned about the clunking than I am the gears whining.
I do plan on taking it in to the dealer soon, but find the time.
Anyone else experience these issues with the rear ends of your Libertys ?
BTW, our 2012 Liberty only has 6,900 miles on it right now.
LibertyFever
New Brunswick, Canada
It's sounds to me like a bad u-joint. Crawl under you Jeep and grab the rear driveshaft and try to move it. If your u-joints are bad there should be some movement.
If it's not that then it's a pinion bearing issue with the rear axle.
sent from my Galaxy SIII & Tapatalk4 beta
Bmxer524
Lindenhurst, New York
You're under warranty still. Take it in and have them check it out. If you're getting a clunk then something is definitely wrong.
